Can i change from Genteq fm19 to Ever green 6006
Received 0 Votes
Is that supposed to be 6005 ? I don't know of a 6006.
The 6005 is used when you want to install an ECM type motor where there was a PSC type motor.
According to the instruction sheet.... you cannot use this motor to replace an OEM ECM type motor.
The 6005 can use high voltage or low voltage switching so it's somewhat similar but the wiring will be different than an OEM setup.
