air flow problem
air flow problem
I purchased new lg mini split and had it installed approx 9 mos. ago. From day 1 the air flow out of the 2 indoor units was very weak. what is the problem?
I'm not sure you could do anything about it now.....
you should bring that up with your installer. Weak airflow is a problem in some brands.
Mini splits often have user options on remote control to set fan speed and swing discharge louver action.
Some units come with clear plastic over filter element that has to be removed.
