New Condenser Proposal
Old 10-01-21, 09:15 AM
O
Received 3 Upvotes on 3 Posts
I received this as a replacement for my old AC condenser unit I've created past posts about. Does it look legit or worthwhile? The guy's charging $500 labor on top of the costs.
Thanks!
Old 10-01-21, 05:15 PM
R
Received 195 Upvotes on 177 Posts
Why would you put an R-407C unit in? And keep an old evaporator coil.
A better investment would be a matched R-410A system.
Old 10-01-21, 06:53 PM
F
Received 21 Upvotes on 18 Posts
I don't know your back and forth with the company responsible with this invoice but it seems odd. I'm in agreement with "roughneck77" and would think a HVAC company wound recommend a R-410a system as well. It also seems odd that they would list a pre-charged R-407c condenser right after listing a 25 lb jug of refrigerant, -did you ask for extra refrigerant on the side?-
Old 10-02-21, 07:41 AM
O
I'm not entirely sure what answer to give. He said that the refrigerant needs to be replaced with a new condenser, but the attic equipment doesn't. Is there a mistake here I should correct?
TBH I'm on the fence about selling my home and purchasing a different one so not sure if I want to do a complete overhaul of the system or should just get the system passed on a home inspection. I would hope, in the least, that I can replace this part and move forward with other components if need be, unless it's just a better idea to replace the whole thing at once.
Let me know what you think.
Old 10-02-21, 08:01 AM
Received 3,627 Upvotes on 3,251 Posts
I'm not real familiar with R407.
What is the current refrigerant in use..... R410a ?
If yes....I wouldn't switch.
A 5 ton coil is big.
25 lbs of R407. That seems like an awful lot.
Old 10-02-21, 08:36 AM
R
It’s a better idea to replace the whole thing and move to R-410A.
Pete, 407C is an R22 substitute that works with POE. This contractor is proposing leaving the old evaporator and just replacing the condenser.
Old 10-02-21, 08:51 AM
O
It's going to cost upwards of $8,000 to get the whole thing replaced. Not sure if it's worth the investment especially if I'm going to sell this house on the near horizon.
Old 10-02-21, 12:45 PM
R
Look at it this way. You could replace the condenser and have the old evaporator start leaking a week later. Which will require coil replacement. And will require conversion to R22. Then when it’s time to do the condenser again it will need reconverted to R-410A.
Plus if a home inspector picks up on an old evaporator with a new condenser, you’ll likely be giving money at closing for a new air conditioner to the buyers.
Old 10-02-21, 08:24 PM
O
Well ain't that a B.
Old 10-02-21, 08:32 PM
F
Reading your past history with this system it would seem that "roughneck77"'s talk of a leak in a week could be more than possible. What confused me on the invoice was the Evcon part number is for a pre-charged condenser. The invoice also shows a charge for an additional 25 lb jug of refrigerant. That seems excessive.
Old 10-03-21, 01:36 PM
Houston204's Avatar
Received 89 Upvotes on 82 Posts
It looks like he gave you his cost on material and he is going to charge you $500 above that. (More like $800 if he keeps the jug of refrigerant)
You are taking a gamble keeping the evaporator coil.
I also recommend getting a quote from someone else to replace the condenser and evaporator coil.
Old 10-03-21, 07:00 PM
O
Can I keep the current evaporator coil with a new 410 but change it later if needed?
*Edit: Sorry if it's difficult for me to follow along. I'm hoping I could keep the equipment I currently have in the attic and replace only what's needed. But it sounds like a full-system overhaul is the best option ATM.
Old 10-04-21, 02:17 PM
R
No, that’s not an option
