Do I need a new AC unit
Old 10-15-21, 07:23 PM
Received 2 Upvotes on 2 Posts
My thermostat battery was dead and the outside unit was ice all over it.I turned off for 2 hrs and back on after ice was melted.After 3 hrs it went from 82 to 78 and started icing up again,I just turned it off.It is 22years old 1.5(I think) ton carrier
Top Answer
10-16-21, 09:04 PM
roughneck77
roughneck77 is offline
Received 195 Upvotes on 177 Posts
Likely was not caused by a dead battery.
Old 10-15-21, 08:36 PM
R
Is the blower motor running?
Is the evaporator coil clean?
Is the air filter clean?
Is the air filter a high MERV restrictive type?
Are the supply air vents obstructed or closed?
scrambledlife voted this post useful.
Old 10-15-21, 08:52 PM
The motor running.
Evaporator coil,I did not check.
It is now.I changed them.
No.
I have been remodeling the house and with dust and paints filter was dirty too.
Old 10-16-21, 05:56 PM
R
Shouldn’t run the unit in an extremely dusty environment. If the filter was very dirty the coil may be clogged as well.
Old 10-16-21, 08:05 PM
As soon as get a break ,I will open it and look at and maybe I could post a picture too.And you are 100% right.So,this was not caused by thermostat battery was dead.
Old 10-16-21, 09:04 PM
R
CircuitBreaker, scrambledlife voted this post useful.
Old 10-24-21, 12:52 PM
I have found a good(ac repair man) ,I knew him from restaurant business years ago.He is seek now as soon as he gets well,he said he will look at.I will let u know the outcome of it.
