Hi,
My bedroom's air conditioner suddenly started behaving odd out of the blue. The unit is some no-name Chinese 0.6HP unit, but it's just 1 year old and served me well, and it's still cooling well but the problem is that the cooling/resting cycles are too long.
It uses a physical dial to set the desired thermostat temprture, and until now i always kept it at "5", which is the midle of the scale, but suddenly it will only start cooling once iset it to at least "6" on the thermostat scale.
In addittion to that, the cooling cycle is now very long, in which it cools my room very well, actually feels like it cools it more than it should (maybe because i suddenly need to crank up the thermostat more?) and afterwards the "resting" period is also very long in which my room's temperature raises considerably, and this large difference in tempratures during the whole cycle is literally making me sick, i wake up dehydrated and dizzy.
I have successfully replaced the thermostat, but to my surprise, the cooling behaviour havent changed.
So we have an air conditioner that obviously have the ability to cool, but suddenly "forgot" when to start and stop and how much to cool and when to start cooling again, and the thermostat was not the problem, does anyone know what can the problem be?
I hope my explanaion is clear English is not my native language, I highly appriciate any reply
Thank you
it's done for I had a "Sunbeam" branded one do this well I took the front off as curiosity got the better of me well it had a refrigerant leak! It was icing up and the ice caused the short on long off cycles as it took a while to melt and get back to normal "temps" for the thermostat bulb to reactivate the contacts thus starting the compressor.
I have been in my 2100 SF, 10-11-year-old home in SC with builder grade Lennox AC, coil and furnace. The outdoor unit is very loud and makes a clunking sound when it turns on and off. Had it serviced and suggested it is close to the end of its life.
The outdoor unit is a 3 ton. The coil is 3.5 ton and the furnace is 4 ton. I've had two quotes. The lennox dealer recommends upgrading to a 3.5 outdoor unit and 3.5 coil. He stated there was likely pressure build up because of the mismatched sizes and larger furnace, and suggested adding some type of loop duct to relieve that pressure. The furnace will remain.
A trane dealer stated the three different sizes was probably what was best at install and recommended staying the same size. He didn't mention the pressure issue or the need for a loop duct. He did state the lines to the outdoor unit would need to be replaced to handle the 3.5 ton outdoor unit. Lennox dealer didn't mention that but did state they would swap out lines if needed.
Both are about 16 SEER and cost about the same to install/replace. Looking for some advice/clarity. Thank you in advance.Read More
I have an issue exactly like @perko9 did in his thread here
https://www.doityourself.com/forum/air-conditioning-cooling-systems/525406-honeywell-compressor-contactor-upgrade-problem.html
I would just like someone to confirm the wiring I have so far before I slam the power through & possibly blow my compressor.
[img]https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x971/20211108_140252_39014b3d81fa45249b6c15844f610dd0c1413c66.jpg[/img]
[i]Old wiring, before removing the old part[/i]
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x971/20211108_143310_af7e7d725e662b2e66e776fce650ad4b6904ecc4.jpg[/img]
[i]These are the two C poles/terminals on the old contactor/transistor that @skaggsje could not see [/i]
[img]https://cimg1.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x971/20211108_143316_27d3cbcdabe17576958862003dbf4fd6cb267a41.jpg[/img]
[i]What I have so far, with power disconnected. [/i]
I guess I'm just doubting myself, but that last thread would have been perfect information if the OP had posted a shot of his solution & final wiring at the end before it was closed. Does this look right?
Read More
