Signs Of Carbone Monoxide or ...?
Old 01-11-22, 09:18 AM
B
Received 4 Upvotes on 4 Posts
Opened up furnace to light up pilot light (turned them off last spring) and found these white, ashes like stuff. Is this a sign of carbon monoxide or something just as bad?
Both Units are old dated 1987. I have always had CM gas sensor near each unit and in rest of the house. I do plan to replace the furnaces later this year but for now I just wanted to know if the white stuff is early onset of C.M. gas?
Top Answer
01-11-22, 10:08 AM
Pilot Dane
Pilot Dane is offline
Received 1,952 Upvotes on 1,748 Posts
Carbon monoxide is an invisible gas. It does not leave mouse droppings. Most of what you are seeing is corrosion (rust). To know if carbon monoxide is getting into the home the furnace's heat exchanger should be inspected for cracks and corrosion since it's job is to keep combustion gasses separate from the house's air. Your CO detectors in the house are a great bit of insurance so make sure they are relatively new (they have a limited lifespan) and have working batteries.
Old 01-11-22, 10:08 AM
P
bambata, CircuitBreaker voted this post useful.
Old 01-11-22, 11:02 PM
B
Ok I will have them came back and do that.
All the same, separate from the alleged mouse droppings (had me in stitches, but actually it's just debris) the issue of concern for me was the white, ash like stuff. Is that a normal find, in this location, in a gas furnace? Is it an indication of anything? I remember last spring cleaning and vacuuming a whole lot more ashy stuff than you see in the pic.
Old 02-24-22, 04:18 PM
B
Update: home warranty approved installation of a new unit. The downstairs unit does such a good job heating upstairs as well. As such the new unit upstairs is barely running. Seems this phenomenon does match the tech's claim about upstairs unit not cooling effectively in summer daytimes, if the downstairs unit ain't running. I will be testing that out this summer. Thanx everyone.
Old 02-24-22, 10:19 PM
Received 3,609 Upvotes on 3,235 Posts
They've approved replacing the furnace..... .
A gas furnace in the basement is usually all that's needed to heat an entire house because the hot air rises. However... an A/C in the basement provides minimal cooling to the second floor.
