Is my air filter too restrictive? I first choose the cheap one at home depot blue color for 99 cents but that is MERV1
So I chose now the next up MERV5 but now whenever the air sucking starts, the filter concaves inside proving that it is restrictive. So should I go back to MERV1 the blue color cheap one?
If this is too restrictive then how do some people use MERV5 and above sometimes I hear MERV10-15. Do they have a different set up?
Why do you think you need a higher MERV rating?
Think about what that little box in the basement with a 1-inch-thick filter does. Do you really think it's going to filter the air you breath for the whole house?
What does the furnace manufacturer recommend?
Unless you have mild dust problem or a mild breathing problem, I would stick with the cheap ones. You want to filter out large particles like dog and cat hair in order to keep the innards of the furnace relatively clean.
But how about the small particles?
What Marq said.
Again, what do you think or expect the filter to accomplish?
Against all the advice and orders from our store managers and the 3M reps, I continue to advise customers not to buy into the high-end filters unless they have a very specific need and even then, don't expect much.
First, what does the furnace manufacture recommend?
Then, start out with the cheapest filter. You want to eliminate large particulates and debris from getting into the motor, fan and internal workings. You can't stop the micro type particles from getting inside. If that works and you have no particular problem with the way the furnace works then you're good. Stop trying to improve on it.
If you have a dust problem or an allergy, then move up to the next grade of filter (don't bother trying to understand the MERV rating. That's for the scientist and technicians.) Keep moving up a filter grade until you find what is comfortable. You want to get the right filter to coincide with you furnace and your comfort.
That filter looks like the most basic unrestrictive pleated air filter available at Home Depot. It will bow in because it doesn't have a good wire backing available on slightly better filters.
A manometer is the tool that I use to measure the external static pressure across the furnace. The furnace states the desired ESP but it is usually .5" W.C.
Many systems have undersized ductwork. That filter grill may be too small as posted earlier. ( not just the filter).
I usually recommend the least restrictive pleated filter available.
2014 Trane AC 5 ton system with touch screen lcd thermostat
Reading the manual, the thermostat has a 10 year battery for keeping time in event of a powerout. The thermostat is run by a remote 24 vac transformer. There are also 3 AAA batteries in the stat. The manual says they are for armchair programming of the unit. It says you can remove them or leave them in. I am guessing they provide prower so you can sit and program the stat but are not needed after you plug it in. Does anyone know if I am interpreting this correctly? I just removed the unit from the wall to check the batteries after 7 years, and what a mess.Read More
I have a 1840sf ranch home all brick that is 12 years old. It had a 3-1/2 ton unit that worked. I had a HVAC company quote and install a York 4 ton 17 seer modulating condenser model HMH72B481. They also installed a 5 ton York air handler AVC60DX21. In heat mode the unit runs for 5-6 minutes than the fan goes into a very low speed mode for 8-10 minutes before shutting down than restarts 8-10 minutes later. When running the sound out of the vents are extremely noisy and where the air return is, the sucking noise is very noisy as well. Room temperatures are not consistant and I'm worried about moisture and possibly mold. I believe that everything they did is oversized. They HVAC company said everything is fine. Any comments?Read More
