a/c internal leak
Old 04-23-22, 03:37 PM
B
a/c internal leak
here is a new one when pumping Feron back into the condenser unit i close the high side service value then pump it back on the low side it goes it goes into a vacuum they i close the low service value my gauges are now in a vacuum and the caps are off the service values .now i watch the gauges after about the gauges start to raise up after about 5 min the gauges are now about 100 psi . now could this mean a internal leak in the one of the values
Old 04-23-22, 05:25 PM
Received 3,596 Upvotes on 3,225 Posts
Welcome to the forums.
Unfortunately this is one aspect of A/C servicing we don't cover.
The board administrators have requested that charging instructions and pressures not be discussed in the open forums due to EPA refrigerant handling and licensing requirements.
Sorry.
