How Sufficient is Vacuum Pump made from 1.5 Ton AC Compressor
Hello Everyone,
I started learning ac repair and converted my Samsung Ac 1.5 Ton Rotary Compressor into vacuum pump.
I would like to know is it sufficient for pulling air and moisture from the system?
It become very hot when pulling vacuum for more than 20 minutes ?
It is not sufficient.
Compressors are cooled via refrigerant vapor. When no refrigerant is flowing they quickly overheat.
They will also not provide low enough vacuum to properly evacuate the system.
