Condo AC leaking
Old 09-10-22, 05:54 AM
Z
Condo AC leaking
Hi
I ve been struggling of my living room ac leaking for half month. Check drain pipe working good. But water leaking from the middle of the wall where control panel installed and another spot is under left of drain pan. Is it leaking from upstairs and main pipe. Here’s some pic
and video of leaking:https://drive.google.com/file/d/1h8g...w?usp=drivesdk
Last edited by PJmax; 09-10-22 at 11:04 AM. Reason: added second labeled pic from video link
Old 09-10-22, 11:05 AM
Received 3,627 Upvotes on 3,251 Posts
Welcome to the forums.
The picture posted is too close. Can't get a reference point. The video is good.
I added the second labeled picture.
The problem is not your coil or drain.
The condensation is coming from over your coil. (blue arrow)
It could be due to an air leak and condensation or that water that is dripping is coming from the unit above you. I'm inclined to believe the second choice.
Old 09-10-22, 12:08 PM
Z
Hi
thanks for the reply, I should contact management office to inspect upstairs.
