Do thru the wall AC units require a sleeve ?
Old 02-25-23, 08:12 AM
Do thru the wall AC units in a ground floor frame building require a sleeve or can the installer build a frame around the AC unit ?
Old 02-25-23, 09:01 AM
R
Received 185 Upvotes on 169 Posts
They require a sleeve as so the airflow is correct.
Old 02-25-23, 01:03 PM
Received 3,422 Upvotes on 3,068 Posts
A thru the wall A/C comes with it's own sleeve.
A sleeve needs to be installed so that you can slide the unit out for service too.
CircuitBreaker voted this post useful.
