Delonghi Penguino PAC AN140HPEW Heat Pump/AC
Old 06-08-23, 12:23 PM
F
Hi, got this portable AC/Heat Pump from someone who burnt me on it(I should have known better)... Anyways it is flashing HL as soon as its been plugged up. I have taken the casing off of the unit to have a better look, there is absolutely no water anywhere because it has been in storage and unused since last year(according to the person).
So, I have verified there is not water, I have checked the float switch and it seems like it should be working it has a nice little click when raised. I have followed the wiring back to the circuit board, I do not see anything on the board that is alarming(blown caps, burnt marks or anything) I have connected the 2 float switch wires together to see if I could bypass the switch but it did nothing for it... I have verified 120v coming in from electrical.
There is a little black box on the circuit board that gets power from a brown wire and looks to me like its supposed to put power out to the top of the compressor via the red wire that comes out of the little black box also. It gets 120v on the brown wire but the red wire has nothing.
I know its probably a lost cause but I am trying to figure this out since I wasted the money on it... Any help would be appreciated. Thanks
Little black box in the top right of board has power in on brown but no power out on the red
Old 06-08-23, 01:04 PM
Received 3,609 Upvotes on 3,235 Posts
Your pictures are too small to be helpful.
The manual doesn't even list HL as a fault code. It does list Hi.
That "black box" in the corner is the compressor relay.
The board tells that relay to turn on to run compressor.
Old 06-08-23, 02:28 PM
F
Old 06-08-23, 02:31 PM
F
Old 06-08-23, 02:35 PM
F
Old 06-08-23, 04:35 PM
That wiring diagram is illustrating an inside and outside unit yet the manual disagrees.
Indoor and outdoor fan motors.
I've never worked with a portable heat pump unit before.
On the surface it appears to be marketing hype.
Do you have two independent units that form a system ?
It may be indicating two motors in the same unit.
There is no technical info on your unit which is normal for Delonghi.
Downloadable manual
Old 06-09-23, 04:29 AM
F
Old 06-09-23, 04:31 AM
F
It does have 2 systems, along with 2 blower motors.
