how to cool one bedroom
Old 12-01-23, 11:48 AM
I
Received 4 Upvotes on 4 Posts
One bedroom is small with only one window within a shaft like area. The room has a ceiling fan and the house has HVAC. I am constantly fighting thermostat wars with my 16 year old son who says his room is too hot. I looked at portable air conditioners on Consumer Reports and they aren't highly recommended. Any suggestions how to get one room cooler?
Old 12-01-23, 02:03 PM
Received 3,881 Upvotes on 3,478 Posts
Not sure what your picture is showing us.
Not cool enough on the second floor is an extremely popular problem.
A window unit would help.
A two line vent stand alone A/C would help.
Better insulation in the attic would help.
There are many ways to go.
Old 12-01-23, 02:32 PM
P
Received 2,107 Upvotes on 1,886 Posts
One problem I've seen is a lack of return for the air capacity when the door is shut. You can do a test by leaving the door open when the AC is running and see if that helps.
Old 12-01-23, 03:34 PM
C
Received 349 Upvotes on 292 Posts
I tried portable AC units for our MBR. I threw both of them away and had a mini split installed.. You might try an over the sill, low profile window unit. I've never owned one but it might work for you.
Old 12-01-23, 05:40 PM
I
Thanks, good ideas. We have new insulation in the attic and it's a one story house. The rooms cools off when the air conditioner is on but my son still complains it's not cool enough. I will check out an over the sill, low profile window unit.
