Looking for a duct fan on-off contoller.
Old 02-23-24, 12:07 PM
B
I'm looking for a controller to turn a duct fan on at a low temp setting, which I can set, and turn it off at a high temp setting, which I can set. Much like a high-low limit switch but can be set below and above about 72 deg F. It should have two manual setting dials. One for the low temp turn on point, and one for the high temp turn off point. I found a couple but their meant for furnace applications. This is just to turn on and off a commercial grade 6" duct fan which runs off of 120 VAC. Any idea's or suggestions out there?
Old 02-23-24, 03:24 PM
Received 3,991 Upvotes on 3,582 Posts
Welcome to the forums.
I spec and buy dozens of temperature controllers and get them from ebay.
Temperature modules starting around $10.
I typically require a single activation point. Your request is a little different.
Try this..... dual setting temperature controller
Old 02-24-24, 03:52 AM
B
That looks like it'll fit the bill. The probe is a little overkill for my purposes but not a game changer. Just have to find one that ships to Canada. Thanks for the head's up.
