A/C air handler drain issues
Old 05-24-24, 04:53 AM
edit: this is not cooperating with me, sorry lol
Old 05-24-24, 05:10 AM
the_tow_guy's Avatar
Received 262 Upvotes on 213 Posts
Not sure why your pics don't show, I can see them in Mod edit mode. I'll see if I can fix that.
Check pic procedures here:
How to insert pictures
Old 05-24-24, 03:10 PM
P
Received 2,265 Upvotes on 2,018 Posts
You posted your picture correctly. With my moderator's magic wand I can see your photo in your post.
You did not say what your issue is. It looks like your condensate drain piping is broken completely off. If the pipe is glued into the fitting then you'll also have to replace the bulkhead fitting in addition to replacing the missing piping.
Old 05-24-24, 08:41 PM
Received 4,099 Upvotes on 3,682 Posts
Welcome to the forums.
I posted and labeled your picture for discussion.
A and B are the two drain connections.
One is slightly lower than the other. Look closely.
They used the B connection. The connections in the air handler are 3/4".
Unscrew C from the air handler.
D looks like a 3/4" to a smaller size reducer.
The drain line should not be reduced from 3/4".
3/4" PVC male connector
Old 05-26-24, 08:35 PM
Thank you for fixing and answering my thread. Appreciate it alot.
I changed the fitting with the correct one, had to buy new tube and ran it to the drain. Itís been running well for over a day now, so thank you.
