Moving air handler from attic to garage
Old 05-28-24, 12:56 PM
12 y/o system has bad TXV. I want to have new unit put next to the other unit in the garage. It looks like there is clearance as there is a closet on the other side.
Return would be just inside the closet. Is there any issues with this behind this louvered door? Otherwise, I would need to get new doors and redo the drywall. It would take 14 inches inside of closet.
Any input is appreciated.
Old 05-28-24, 04:41 PM
Received 4,153 Upvotes on 3,730 Posts
Your two pics are visible in your post.
12 years is not very old. Have you considered having the TXV replaced ?
Not sure I'm following but if the return on the new unit is inside a closet then you need a louvered door.
Old 05-29-24, 04:04 AM
Thanks PJmax;
The old unit, attic mount, has broken many times with massive air leaks that I am constantly fixing due to a tight/poor installation. At this stage, In South Florida, many of these units have a max life of 10 - 15 years. I researched how to properly retrofit a closet and think I am going to go that way, thanks for the assist.
