Ruud Cabinet Screws
Old 06-01-24, 06:03 PM
G
Ruud Cabinet Screws
Did the yearly coil cleaning on the condenser of my sister's 2 1/2 ton AC unit. Some of the screws are not really tightening up anymore after 25 yrs service. The screw head is 5/16", is there a standard oversize screw to use in that case? Size?
Old 06-01-24, 07:55 PM
Former Member's Avatar
Received 1 Upvote on 1 Post
I keep a container of the std #10 x 3/8" hex washer head sheet metal A point screws and then a container of #12 x 3/8" A point hex washer head screws in my tool box for the holes that get loose. No matter how careful you are some just seem to strip out.... If you have a Fastenal store close by they will have anything you want most of the time.
Old 06-02-24, 04:12 AM
B
Received 322 Upvotes on 284 Posts
The diameter of the part of the screw containing the threads is more important than the head diameter for a replacement screw. Is the old screw thread a machine thread or sheet metal?
Old 06-02-24, 06:18 AM
G
They're sheet metal. I'll get a couple packs of the #12's next time I'm at HD. Thanks!
