Haier window air conditioner
Old 06-12-24, 06:38 PM
A
Hello, I bought a used Haier air conditioner. When I set the temp I want 63 degrees, it will go back to 72 and stay there. The appliance does not stop like a normal one would and then restart. I cleaned thermastat wire and everything inside looks nice and clean.Also when I set timer it shuts down. Any Ideas what's wrong ? Haier model # ESA406K-L. 6000 BTU Thanks
Old 06-13-24, 05:58 AM
P
Received 2,309 Upvotes on 2,054 Posts
If the AC blowing cold air?
The 72 is probably the room temperature.
Old 06-13-24, 07:15 AM
A
Yes, the air coming out is very cold. Thanks for the reply.
Old 06-13-24, 07:17 AM
A
Also after about a half hour the room is definitely colder than 72 degrees but it still says 72 degrees.
Old 06-13-24, 10:18 AM
Received 4,139 Upvotes on 3,717 Posts
Once you set the operating temperature..... the display defaults back to room air temperature.
Old 06-13-24, 02:32 PM
A
Yes but, it should be lowering from 72 degrees. The room is lower than 72 degrees. Also when I set the timer even though I set it to 10 minutes it shuts right down. Changing to energy efficient doesn't change anything. Inside of unit is super clean. Like new. Thanks for your reply.
Old 06-13-24, 05:23 PM
Sounds like a problem control board. Would be too costly to repair.
Standard A/C is the blower runs and the compressor cycles at temp.
Energy Efficient turns the blower and compressor on and off together.
Old 06-13-24, 05:44 PM
A
Oh, Thanks. So not thermostat ?
Old 06-14-24, 04:45 AM
P
The trouble with modern appliances is that there is often no separate thermostat as a individual module. Everything is often integrated on one control board.
