Blower fan not staying on
Old 06-20-24, 05:17 PM
R
I went out of town for Memorial Day weekend, and returned to an iced over A coil and ac lines. Thawed it out, and the condenser would turn out, but not the blower fan. Determined the control board was fried, and replaced it.
Now the fan will run for about 30 seconds and then shut off when the thermostat is set to Cool and the fan is set to either on or auto. If the thermostat is set to off with the fan set to on, the fan runs continuously.
Any ideas?
Old 06-20-24, 05:28 PM
R
I also ran the internal component test, and everything seems to function as it should for the test.
Old 06-20-24, 07:29 PM
F
Is this an ECM blower? Make and model of the air handler?
Old 06-21-24, 04:57 AM
B
Received 322 Upvotes on 284 Posts
Is new control board same as old control board? Could be fan and t'stat switch voltage settings are interpreted differently in new control board.
Old 06-21-24, 06:40 PM
Received 4,152 Upvotes on 3,729 Posts
Welcome to the forums.
At first I would say it's a thermostat problem.
Is it a nest ? That could explain it.
What is the thermostat model.
Furnace/air handler model would be helpful.
