New bathroom
New bathroom
I am renovating a house in France, and my wife wants a bathtub placed in the MIDDLE of the room. I have strengthened the floor with noggins between the 2x8 joists, and will re-cover the joists with two layers of 5/8 plywood. My problem is getting the waste water from the bathtub to the down pipe in the corner of the room. I shall have to drill a 1 and 3/4 inch hole through two of the joists. If I keep this hole above the centre of the joist, will all remain safe? If not, can someone tell me how ? The room is one floor above ground level, and measures 8 ft x 13ft, with the joists going long ways.
Mick W,
This is a mix of info,
NOTCHES OR HOLES IN SAWN OR ENGINEERED LUMBER
R502.8.1 - Sawn Lumber
Notches in solid lumber joists, rafters and BEAMS shall not exceed one-sixth of the depth of the member, shall not be longer than one-third the depth of the member and shall not be located in the middle one-third of the span. Notches at the end shall not exceed one-fourth the depth of the member. The tension side of members 4 inches or greater in nominal thickness shall not be notched except at the ends of the members.
R502.8.2 - Engineered wood products
Cut's, notches and holes bored in trusses, laminated veneered lumber, glued laminated members or I joists are not permitted unless the effect of such penetrations are specifically considered in the design of the member.
CUTTING, NOTCHING AND BORING
JOISTS: UBC 2517(d)(3)
NOTCHING: Notches in ends of joints shall not exceed 1/4 th of the joist depth
2X6 = 1 3/8", 2X8 = 1 7/8", 2X10 = 2 3/8", 2X12 = 2 7/8"
Notches in the top or bottom cord of joists shall not exceed 1/6th of the joist depth. Notches shall not be located within the middle 1/3 of the span of the joist.
2X6 = 7/8", 2X8 = 1 1/4", 2X10 = 1 1/2", 2X12 = 1 7/8"
HOLES: Holes in the joists shall not be located within 2" of either edge (top or bottom) of the joist. Diameter of holes shall not exceed 1/3 the depth of the joist.
2X6 = 1 7/8", 2X8 = 2 1/2", 2X10 = 3 1/8", 2 X12 = 3 3/4"
WALL FRAMING: UBC 2517(g)(8)
CUTTING & NOTCHING: In exterior walls and interior bearing walls, notching in studs shall not exceed 25% of the width of the stud.
2X4 = 7/8", 2X6 = 1 3/8"
Cutting & notching of studs in non-bearing walls shall not exceed over 40% of the width of the stud.
2X4 = 1 3/8", 2X6 = 2 1/4"
2517 (g)(9).
Bored holes. Holes in studs of bearing walls shall not exceed over 40% of the width of the stud.
Holes in studs of non-bearing walls shall not exceed 60% of the width of the stud.
2X4 = 2 1/8", 2X6 = 3 1/4"
Hope this helps!
2517 (g)(9).
Hope this helps!
Originally Posted by majakdragon
Mick W, Welcome to the DIY Forums.
I moved your question here because it is more "structural" than piping. Should get better answers here.
