Range Hood required?
Received 0 Votes
I know a range hood is a nice touch - but is it typically required by code? I'm remodeling a kitchen, putting the range on an island - and hate to spend $1000+ for a suspended hood if I don't have to.
thezster,
how about a down draft and save the $1000 for more beer? As far as code I am not sure with a remodel if there was not a hood before that you would have to install one.
Brian Garrison
Brian Garrison
Received 0 Votes
Thought about a downdraft.... but that's still gonna run $600+. Those things are spendy...... (just to get rid of a little smoke from that grease fire
) As far as there being one before the remodel..... I don't see one..
This is a fix n flip - if that explains the financial aspect a bit more.....
Received 0 Votes
Many localities don't require ventilation, preferring to permit non-ventilated systems since ventilation exhausts so much heat to the outside. This explains why the typical apartment or condo building smells like an ethnic restaurant upon entering.
Even if a hood was not required before, a remodel would require compliance with current code, right?
In a fix n flip, you may be able to get away with no hood, if code permits. But then you'd have to count on selling to a buyer who has never cooked before. In which case, you may as well install a cheap range also.
Received 0 Votes
Sometimes I miss the forest for the trees. You're right, of course..... so the remodel gets modified (can't knock that wall down now cause it's where the overhead vent/microwave goes) for the sake of doing it right!
Thanks - you are right on!
