pick an archetech
pick an archetech
how do i go about picking a good reputable archetech to build an addition for my bungalow in the michigan area.
Look in the yellow pages under architect? As far as a "good one" just ask around and get some names. When you find someone ask to see some of their recent work. Then give them your bank accound number as they will be emptying it anyway and enjoy your new bungalow 26 months later!
Woodwright,
Unsure why you feel you need to hire an architect but lets assume you are not aware of the differences between the two - architect or designer.
In reality, 90% of all residential projects do not require an architect. I am not saying or implying that architects are not needed but facts are facts. The architect may charge the prospective homeowner in the range of 5%-15% of the project cost, whereas a desiger may only charge on the average 3% to10% for "Construction Drawing Set" . The rule is the lower the projected cost, the higher the fee.
The difference is that designers are not licensed architects but may have similar education and background to that of a licensed architect BUT they have not gone through the licensed exam procedure. Most designers have actual work experience in place of the advanced degrees and licenses. It is one thing to be book smart but having no experience on the job, knowing what can or cannot be done is not taught in school. This is not true across the board and I wish not to offend any architects that are extremely skilled in accomplishing the needs of any client. Real life issues are very different than what is taught in school.
In Michigan, Residential Building Designers are limited to what we can do per House Bill #5819 of 2002. Most states have similar bills that prevent designers from designing anything over 3 stories, anything over 3500 sq ft of "habitable space" and they cannot do commercial work. These would have to be done by an architect.
When looking for an architect, you can contact, http://www.aiami.com/home.htm.
When looking for a designer, you can contact, http://www.aibdmi.com/.
Regardless of who you hire, check out references, look at past projects and make a sound judgement of who is better to accommodate your needs.
Hope this helps!
Hope this helps!
Woodwright,
I'm probably pushing the limits here as far as advertising, but you're in MI, and Doug's in MI, and you are talking about remodeling a "bungalow".
You DON'T need an architect, you need a designer.
Look in the Yellow Pages, or PM Doug, or do both.
