Steel Beam in Basement
Old 09-27-08, 10:34 PM
I
I am building a new house in Saskatoon SK. It will be a 1000 sq foot bi-level. I want to avoid teleposts at almost any cost. I work in the steel industry so I can get a beam at a very resonable cost but I don't know what size to get. I would not want one that is wider than 14" (just to ensure descent headroom) but I don't care how heavy it is. Can sombody please tell me whether it be by their knowledge or experience what size of beam I should get eg 14 @53. The span will be at the most 35'
Old 09-28-08, 09:10 AM
pmgca's Avatar
Hi Ianms,
For your own safety (and your family's), let me explain some issues, starting with the building codes
As we all know, there is a building code, but each state / province has its own version / adaptation. An Architect, Engineer, etc must elaborate the interpretation / application of the Building codes, calculation of structures and foundations, for each project, etc. Not only for the technical understanding of these issues, but for the liability.
An advice regarding a technical subject (something basic as the beam dimension and independent if you are paid for this advice or not) implies liability.
Structures / materials are quite different depending the characteristics of the project, load, soil / topography, wind conditions and seismic calculations.
Certainly, dimensioning a beam is not a DIY task
Old 10-01-08, 05:52 AM
OhioDraft's Avatar
can't do that because i can't interpolate the loading conditions without either seeing it for myself or looking at a full set of plans. xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
what that gives you is a starting point and ultimately you would need to get it verified by an engineer. that would be a decent size piece of steel, comparitively.
