Structural Modifications?
Hi there, I currently have a situation where part of my second storey house is supported by 3 metal post/columns, but I want to modify it so that I can drive a car through the 3 metal post (ie. make the gap wider between 2 of the post)
I imagine this will probably be achieved by replacing 2 of the post to a thicker post, and adding a steel beam or something similar between the 2 thicker post...
but how would I go about doing this? ie how can I support the house while replacing the post and adding the beam etc.? What is the easiest way? Thanks in advance for any help...
Welcome to the forums
Generally, this kind of modification requires a structural engineer on site to assess the situation
You definitely want the engineer's input! You need to know for sure what you install will carry the load with no future issues.
After the engineer signs off on what is needed, you'd built a temporary wall to carry the load while the beam is put in place.
thanks for the input guys... so I need to specifically look in the phone book for "structual engineer"? not any licensed builder?
with this scenario, what I can't visualize though, is even if you use a temporary wall or if you use a temporary pole or whatever, how do you manage to get the old pole out and "swap" the new pole and beam in at the same time? Say if you built a temporary wall, got the old column/pole out, but when you try to swap in the beam, your temporary wall would still be in the way?
I've never had to hire one but I'd think if you can't find a structural engineer in the phone book - call an architect, they should be able to point you in the right direction. The permit office may have a list of engineers or would also be able to point you towards one.
If it isn't feasible to thread the new beam thru the temporary wall, you could set in on the floor, build your temporary walls, remove the post and insert the beam then.
