school project to build up a little water heater
Hello guys, I'm new to the site. I have a project to build a water heater than can heat up to one liter of water and keep it at 48 degree Celsius constant.
Any ideas how I can achieve that? I want to use a little stove burner and some thermostats and I need to figure out how I can wire it.
Thank you for your help.
Regards,
Thomas
Regards,
Thomas
Welcome to the forums.
While we think about the project ...... what grade is this project for ?
I won't do your engineering for you, but will throw out an idea or two to make you think. Since this is a class project and the teacher expects results you need to do the work yourself.
Now for a hint you need a thermostat that is "normally closed" and opens on heat rise. It will need to be in contact with the water that is to be heated and will need to be waterproofed in some way. That is your problem to solve. Next you need a heat source that can be controlled by the thermostat, eg. an electric hotplate. Now combine all this with a container and a reliable thermometer and you are in business. Might add insulation to container to hold heat in.
Here is a hint for a thermostat;
Amico 5 x KSD301 40C 104F Normal Close Thermostat Temperature Control Switch - Amazon.com
Good luck and do have FUN!
RR
RR
Hello guys,
thank you for the hints. I'm grade 10. The project is about how to keep water at a constant temperature because water loses temperature very quickly due to contact with the air.
The teacher told us to ask electricians and to go to forums like this one where more knowledgeable people can help us.
But I don't understand how to wire the thermostat. Isolation is a good idea. I will put sand or clay between the small and the big container. The water will be in the small container.
Wiring thermostat.
You will need a two terminal thermostat. One terminal will connect to LINE Black the other terminal will connect to LOAD Black. It will be a temperature controlled switch for the black wire.
LINE White connects to LOAD White.
GREEN connects to GREEN or to metal frame of heater and/or tank to provide shock protection. This will plug into a GFCI receptacle.
Now I hope a resident ‘Sparky’ will jump in and correct/add to my statements. If they could furnish an easy to understand drawing it would help.
Your basic process is the closed thermostat will supply power to heating apparatus causing it to heat. When the thermostat (in contact with water) reaches cut-off temperature it will open its contacts stopping power to heating apparatus. When water cools to cut-in temperature it will close contacts supplying power to heater. This is an endless cycle repeating as needed.
Have fun!
RR
Have fun!
RR
Imho...
Thermostats in electric water heaters are usually external and NOT in contact with the water in any way. They depend on a heat transfer through the wall of the tank. This is a lot safer when working with electricity.
Also if you can not have access to a GFCI outlet for your project, think along the lines of those GFCI plugs that are on most hair dryers. They function the same way. If there is a difference between the current flow in either line, they shut off. This works without a third prong or ground and is just as safe.
Gerry
Gerry
Received 38 Upvotes
If your teacher disagrees then he/she needs to do a bit of study of the laws of thermodynamics.
Is school providing the thermostats or do you need to specify what you want?
If they are providing the hardware then we need to know what it is.
Absolutely FALSE! The water loses temperature because it is warmer than the surroundings. Heat ALWAYS travels from a point of higher temperature to a point of lower temperature. It can do so in one, or more often, in all of three ways. Convection, conduction and radiation. Only the convection has anything to do with a gaseous intermediary medium.
Wiring thermostat.
Have fun!
RR
Have fun!
RR
Thank you a lot guys. I will get there.
What about using a fish aquarium heater with built in thermostat?
Thank you a lot.
How about a rethink?
Ever hear of an 'Immersion Heater"? Google that and look at the ones for heating a cup of water for coffee or tea. They will boil water in small amount of time.
Found some immersion thermostats, but they are industrial and quite pricey.
Maybe this will jog your thought processes.
RR
RR
Another idea: get this immersion heater Domestic 1500 Watt Electric Immersion Boiler Heater Element Water Coffer Boiling | eBay and control it with this capillary thermostat 30-80 Celsius Degree Adjustable Temperature Controller Capillary Thermostat - Amazon.com
Age
My son has a similar project for school and he's 13 years old (Biol profile class). Should I allow him to work on his own, or maybe ask someone for supervision? Not sure how dangerous connecting the thermal parts would be. Thanks
