Adhesive for Ceramic Tiles
What kind of adhesive would I need to install ceramic tile on to the inside backing of a bookcase?
In a cabinet I'd use construction adhesive. Then if you want to "grout" I would not use ordinary grout but instead would use colored silicone caulk. If it's an intricate grouting job a rag soaked in rubbing alcohol (I like to use 70% or stronger) will allow you to work the silicone like grout without is smearing and sticking badly.
