Bamboo Adhesive
Bamboo Adhesive
I have purchased bamboo flooring from Home Depot, I have not picked it up yet..I have found my own installer 1.35 sq.ft. However I am told there is a huge difference in adhesives. I purchased Acrylic/urethane wood adhesive from HD for 62.07 (4 gallon). Floors Direct is where I have been referred to buy the adhesive for twice the price as well as consider buying my bamboo there due to it being a superior quality than I will be receiving from HD. Is this correct? Thank you.
Don't use anything but a moisture cure urethane, that comes in a metal bucket.
Home Depot was fixing to cost you a lot of hard earned money. That bamboo would have cupped in a heartbeat using that waterbased junk, they told you to use.
Badly cupped bamboo flooring from Home Depot.
I purchased 600 square foot of Home Ledgen bamboo from Home Depot, and used Roberts 1407 adheasive, their recommendation. The floor badly cupped and I don't know what to do. Wish I would have read the articles in this web site before I laid the floor. Anybody got any suggestions. Thanks uj
Looks like the bamboo vendor messed up and realized this:
instructions >in< the box call out 1407 adhesive... but new stickers were added >on< the boxes to use the 1408 adhesive (which is a moisture cure urethane adhesive). Even the adhesive vendor says NOT to use the 1407).
1407:
http://www.qep.com/msds_pds/Adhesive...20Adhesive.pdf
1408:
http://www.qep.com/msds_pds/CANADA/P...20Adhesive.pdf
Brian
1407:
1408:
Brian
adhesives for bamboo
I'm planning on gluing 4 X 8 sheets of 1/2 inch bamboo plywood together to make a 1 inch kitchen countertop. Should I use the moisture cure urethane adhesive mentioned above?
The bamboo plywood comes from Lumber Liquidators in Atlanta, GA area and is selling for $50/sheet. They don't have 3/4 inch, so that's why I would glue two 1/2 inch sheets together. Is that even feasible? Thank you.
LWWPHD
LWWPHD
LWWPHD
LWWPHD
