Repair Cork Flooring
Can anyone tell me if it is possible to repair cork flooring. In manuevering our fridge into the kitchen we managed to put a not so nice scuff in our floor which is now causing the cork to 'crumble'. Is there a seal or something that I can use to cover/repair this area, or any another repair trick.
Thanks
Thanks
Did you resolve your Cork Floor damage issue and how?
I recently had a cork floor installed. It is "Cordoba," stained a dark brown. During the installation of cabinets, the floor was damaged - scuffs, dents, etc. I'm looking for advice and/or solutions on how to repair the damage using wood filler and polish, rather than replacing entire planks.
Some of the damaged areas are deep enough to need some filler. Have you - or anyone else - had success with any wood filler that you'd recommend? Fortunately, the natural irregularities of the cork pattern result in some very dark brown areas amid the medium brown majority of the floor so filling a small area might not be too noticeable. Thanks for any other help you can give!
