bamboo floors and spills?
Received 0 Votes
Hi, I'm considering putting Bamboo click and lock floors in a space where I will be hosting some parties. How does the bamboo hold up for spills? Especially noting that at a party sometimes something gets spilled and doesn't get wiped up right away. Any thoughts?
Received 0 Votes
Normal spills will not cause any problems with click lock flooring. A quality click product has seams that are very tight. This type of flooring has been used in kitchens for years, it is a completely appropriate choice for the area you are describing. What will cause problems is repeated exposure to significant moisture, particularly in the same spot. Melting snow from shoes or a pet bowl that is repeatedly spilled, for instance.
I think we may be talking apples and pears, and don't know which one the OP prefers. One thing, 8 mm laminate, made mostly of mdf is not exactly what I would want in a moist area. It will be affected by water more than the second choice (pears) of engineered flooring (5/8" or so thick). Elleluck, which type flooring are you contemplating? I believe our answers can come closer to "good advice" if we knew.
Received 0 Votes
Thanks for responding... I am considering click and lock engineered floor from Bamboo Importers. I'm also going to put a 3/8ths inch Rubber underlay to give some bounce from the concrete floor. This is going to be a yoga and dance studio, so I need a little cushion.
Any thoughts at all you have from spills to possible issues with the rubber under click lock, I'd be glad for the advice.
thanks,E
thanks,E
Check with the manufacturer's specifications on their underlayment. Too soft an underlayment may cause the wood to crack at the tongue and groove when pressure is applied. I believe you will find a 3/8" underlayment too soft, but if the manufacturer gives their blessing, so be it.
