new Hardwood
Received 0 Votes
new Hardwood
I am installing new hardwood floors in my house and was curious as to whether or not I should remove the old flooring first? There is a subfloor and then original hardwood and then click laminate installed on top. Should I remove atleast one set of flooring? the laminate is in awful condition as well as the original hardwood.
any suggestions are appreciated.
The laminate has to be removed! The original hardwood might be ok to leave in place - is it solid? level? will the additional height be an issue if the original hardwood is left in place?
Received 0 Votes
Subfloor Suggestions
You might try looking into 1/4 inch plywood to put over the hardwood. It will help to level out the bad spots that the old wood will invariably have. I would recommend using a Plainer or Jam Saw to knock down any high spots first though. Good Luck!
I'm afraid you will run into the problem Marksr mentioned about the new floor really being higher than you can tolerate, considering cabinetry, doors, jambs, thresholds, etc. 1/4" plywood only adds to that problem and shouldn't be used as a base for new hardwood. After checking for problems we mentioned, I believe you will come to the conclusion all the hardwood needs to be removed and a fresh start made. Pictures would help if you care to share them. http://www.doityourself.com/forum/el...your-post.html
