Shopping for Bamboo Floor
I am still in the process of determining of whether to put in Porcelain tiles or Bamboo flooring by myself.
I think the advantage of Bamboo is that it is quicker and easier to install right?
If I go for Bamboo, what should I be keeping in mind when I am shopping?
I am looking for either the light white wide blade or if it I go dark, would like to look for something shiny. Could you give some advice and where a good sale might be, such as ****?
Thank You
Thank You
You can do either one as a DIY project. There are differences in flooring, so you need to know which one you want. There is laminate (puke) which is no more than a picture of wood on a substrate of MDF and coated with a wear layer. There is click lock engineered wood, which is a good product, especially for DIY, since it requires no nails/glue, etc. Then you have staple down 5/8" or full 3/4" flooring. Deciding which you want will be a big step.
Finding the right floor can be done on line at one of the box stores or flooring warehouses. It would be difficult for us to tell which would be best.
I have installed the 5/8" caramelized toast bamboo (staple down) in a client's house and in my weekend rental cabin. Went in like a charm and wears like steel.
thanks, if I do wood, for sure I am going with Bamboo. I don't think I will be going with Laminate.
That is the thing chandler, what are the advantages of Click-On or Staple? How would you do it on a staircase?
