Oil for dry wood
Old 04-29-21, 05:56 PM
W
Received 1 Upvote on 1 Post
Oil for dry wood
The sides of my stairs are dry as we have a carpet runner .
What should I use
Murphys oil
pledge
Old English lemon oil -lindseed oil based ?
Wieman lemon oil
Old 04-30-21, 05:33 AM
P
Received 1,768 Upvotes on 1,581 Posts
Most of the things you mentioned are cleaning products. Are you wanting to oil your dry wood or clean it?
Old 04-30-21, 05:36 AM
W
I want to oil it . Seems like from the 2 weimans and old English have oil ???
Old 04-30-21, 06:35 AM
XSleeper's Avatar
Received 1,715 Upvotes on 1,539 Posts
The wood surely is not bare unfinished wood, it likely has a finish on it. Depending on what that finish is, it could be dry looking, as old varnishes tended to do. The solution to that would be applying a new fresh coat of varnish (or poly) because that is what the finish on the wood needs.
If the wood has no clear finish, you could apply a Danish finish such as Watco Danish oil.
Old 04-30-21, 06:57 AM
W
Without re staining it what can I try.
it's a new build about 5 years old. Looks like not alot of sealer was applied or the sun has cooked it off
Old 04-30-21, 09:53 AM
P
On wood I normally use linseed or tung oil but that's on bare wood where the oil is the finish. I assume your stairs have been stained and sealed.
