scoring drywall at a 16 oc to carry downstairs
Old 09-03-02, 01:28 PM
C
Received 1 Upvote on 1 Post
I just then screw the sheet up. Or do I need to tape it?
Old 09-03-02, 02:47 PM
I'm not quite sure what you have in mind, but you won't be able to get a screw to hold in a spot you've just scored and snapped. I assume that you don't have a window that you can get the drywall through. If you must carry the pieces down the stairway, keep them as large as you can (hopefully much larger than 16" strips). If you do just score and fold the drywall, and then put the score lines perpendicular to the framing, I would still think you'd need to tape the seams. But maybe someone will post here who's done something similar to what you have in mind. Good luck.
Old 09-04-02, 02:04 PM
cmp
Actually, my co-worker just finished his basement and couldn't fit even a 4x8 down the stairs. So, to get the drywall down, he cut a hole in his living room floor!
I took a look at the patch of the floor and the joists, and it looks pretty good.
Old 09-04-02, 06:24 PM
C
NOT AN OPTION
Old 09-05-02, 04:02 AM
B
scoring like that asking for problems
Like John said, you want the pieces to be as big as possible. Scoring on 16" centers is no better than cutting all the way thru. You'll still need to screw on both sides of the scoring as if it was a regular cut. If you do this, plan on the scores perpendicular to the studs. Even then, its going to be a ton of extra work.
Old 09-05-02, 07:26 AM
cmp
I didn't say that I'D do it, just that I had seen it done. Of course he has pre-finished new wood floors which are easy to match back up.
