Sewer Smell in Basement
I live in a brick ranch home in southern Ohio. 5 years ago I had the basement sealed and waterproofed from the outside. This consisted of digging around the foundation, installaing a new pvc drain into a new sump pump well. The block foundation was cleaned, repaired and tar was put over the block. Plastic was put over the tar on the complete foundation. There are 3 cleanouts in this system. I run water at least once a year in each cleanout.
This year has been especially dry here so I ran water down the cleanouts more often.
I am getting a sewer smell from the sump pump well. There was never a smell since it was installed.
My question is: Where is it coming from and why? What can I do about it?
Thank You!
Thank You!
Sump Pump Odor
Sometimes a wet, dirty sump can smell like sewer. Pour enzyme digester cleaner into sump and drains. Enzymes digest organic material and odor causing bacteria. If this fails, call a plumber to inspect your sump pump and drains.
Had the same problem and found out that pump wasn't situated properly in sump and was leaving alot of water that eventually stagnated. Being a new build with plenty of dust , it turned into a sludge as well . This gave me that overwhelming stench you're speaking of. Did everything twelvepole mentioned plus cleaned it out and set pump in right position. Everything is fine now, But I still check on it once in awhile to make sure there is no excess water.
Good luck.
Good luck.
