whole house fan
i have a 2 story home that stays hotter upstairs when the lower floor is cool. i was thinking of installing a whole house fan but have no idea of what i need to be aware of before installing one. i have blown insulation in my attic and am wondering if that poses a problem.
Hi:homebruer
Installing a whole house fan is a good idea.
Consider the fact that doing so means drawing in a huge volumn of air. You'll need to leave several windows opened to accomplish that.
{A factor to consider: With the incoming air comes dust.}
You will also need to exhaust that huge volumn of air out of the attic. To accomplish that, you may need to install an attic fan or two of equal air displacement.
I have such a system in place here. I also installed two attic fans to remove the incoming air into the attic from the house. The system works perfectly. But dust is a factor, even near this coastline.
Alternative solution suggestion:
Try window fans as an alternative.
Good Luck,
TomBartco
Personal Quote:
"When experience and knowledge fail,
often times common sense and wisdom will prevail."
Good Luck,
TomBartco
Personal Quote:
