How to attach wall framing to cement floor?
I'll be framing in a new wall in my basement. What's the best way to attach the wood frame to the cement floor? Should I use a masonary bit for my drill, then screw it in?
I framed my basement with 2x4 16" on center and tried using the blue tapcon screws. Not worth the agrivation. I ended up using 3/8" x 3 3/4" Read Head concrete anchors. It is a little over-kill, but very easy to install. Drill 1 3/4" hole with 3/8" drill, insert anchor, drive in with hammer until it is seated and tighten down with washer and nut.
I used the nailer too. It uses a 22 caliber shell that shoots the nail into the concrete. Worked like a champ and lots better than the tapered masonry nails. They just curled up underneath the base plate instead of going into the floor. I also tried drilling and screwing the walls into the floor. Too much time and too much aggravation. Hope that helps!
Have finished many basements and have found that using the 22 caliber nailer is great for keeping the wall in place but I prefer a bit more holding power so I combine the nails which hold the wall in place while drilling the anchor holes and use 1/2" Read heads. You will need a fairly heavy duty hammer drill however especially with older concrete.
