how to fill small gap between slab & wall
I'm looking for something that will seal up a small crack/seperation that is happening between the concrete slab and the wall. It's anywhere from a 1/16 to 1/4 inch and is not really a bid deal, except for minor water seeping on real wet days and the odd bug. The product would have to be relatively thin to seep into this small crack but ideally should expand a bit or else i'd have to pump a lot into it.
Thanks
Pete
Thanks
Pete
try Xypex. It is available in Lowes. It is a cement based product that will fill the crack and keep the water out. If you have to make the crack bigger. Follow the directions.Good product
