suspended ceiling tiles
Old 02-18-00, 09:53 PM
Guest
Post
I am re-doing my semi-finished basement. It already has half the ceiling done with suspended ceiling tiles. The only problem is that they are 2 feet by 33 and 1/2 inches. I can't seem to find tiles with this measurement anywhere. does this mean that I will half to cut tiles to fit, or would the track have to be re-layed? Any help ??? Thanks!!!!!
Old 02-19-00, 04:01 AM
Guest
Post
Parmley:
They do not make the size you have anymore.
Yes, you will have to cut them to fit. That is the easiest way. Good Luck, nothing is easy is it ?
Jack the Contractor
Old 02-19-00, 09:23 AM
Guest
Post
Ugh.... what would be the best tool to use to cut them? Thanks again!--Pam
Old 02-21-00, 05:17 AM
Guest
Post
A utility knife and staright edge will work nicely. Put a new blade in the knife. Put a piece of scrap wood under the tile so you do not damage any flooring or the knife blade.
