Crawl Space Access for finished basement
Old 04-28-00, 08:35 AM
Guest
Question
I am getting ready to fininsh my basement which has a partial crawl space I use for storage. I want to have access after I finish the basement. Do they make crawl space stairs similar to the ones available for attics that you could just pull down from the wall?? If not do you have any suggestions for keeping access to the crawl space??
Old 04-29-00, 05:04 AM
Guest
Post
A small step ladder.
Jack the Contractor
Old 04-29-00, 11:54 AM
Guest
Angry
I am enclosing the crawl space and am looking for suggestions as to what kind of door or how to keep access to the crawl space without making the wall enclosing it look bad.
Old 04-30-00, 04:02 AM
Guest
Post
Usually a crawl space door is about 3x3.
decide where you want it, and you may have to frame in for it. Then probably just build a door with standard hindges. If you do not want to see the door from your basement, you can hang a picture over it or ??? Good Luck
Jack the Contractor
