Puddles on basement floor.
We are in the process of finishing our basement which is built in to a hill. The back of the house is 2 stories. After several rain storms we have found a few small puddles in the middle of the floor with no known source of the water. We are thinking that it is a drainage problem and that the water is coming up through the foundation. We are close to carpeting and very worried about what we can do ourselves to prevent future puddles. Help please.
You have a right to be concerned. When you see these little puddles, that is usually a preview of the big puddles to come. The sus-soil moisture under you floor is too high in the soil. You are going to be look at a drainage situation to divert the water from the hill away from your foundation. I would probably call in a contractor to take a look at it. They will be helpful, and will not charge you. but they will tell you how to probably fix your problem. Good Luck
Draining water heater peridodically
Hello,
Does anyone have an opinion regarding if a gas water heater should be drained periodically to remove sediment and rust?
I drained a bucket from mine this week, and now I am having trouble with the drain faucet. It is dripping now, and I had to close it with pliers to stop it from spraying all over. It is one of those plastic faucets.
I'm wondering if I should bother doing this at all.
Appreciate your feedback.
Thanks,
Todd
Thanks,
Todd
NO ADVERTISING IN FORUMS
XXXXMESSAGE DELETEDXXXX
Forum topics are not to be used as public bulletin board for free posting of ads, solicitations or advertisements of any kind. When forum posts repeatedly promote a product without discussion and advice to a DIYer, it is also considered advertising.
Forum intent is an exchange of helpful problem solving methods and solutions to questions and not public advertisement.
Inappropriate postings not relevent to the intent of the web site or any postings deemed as such by the host, administrator or moderators will be edited and/or deleted.
Policy applies to ALL forums on the web site. No exceptions.
Direct your advertisements to advertisement department. Use "receive advertising info" link provided below.
If you object to policy, contact the Administrator and state your objection.
The "Contact Us" link is provided below.
Failure to comply will result in your being banned from the website.
Web Site Host & Moderator
twelvepole
twelvepole
