Crawl space finishing
Hey Guys, my basement is currently unfinished and there is also a crawl space attached to the basement that is under the family room. This crawl space is about 5ft high and is vented to the outside with 2 vents. It just has a stone floor right now. My intentions are to finish the basement and I would like to use the crawl space as storage. How do I finish off this crawl space so I can close off the vents? My idea is to lay plastic over the stone and then build a wooden floor over the plastic and stone, seal the vents and insulate the walls. Will this work or should I do something different?? Thanks in advance!
