Vapor Barrier on Steel Studs
Old 12-01-02, 06:07 AM
tmarcoux
I am starting the process of remodeling my basement. I am using steel studs for the first time and I am loving it. However, I need to install insulation and a vapor barrier to the exterior walls. How can I accomplish this? What can I use to adhere the vapor barrier, then subsequent insulation to the steel?
Old 12-10-02, 11:18 AM
T
I'm sure construction glue would work.....
