Attic conversion
Attic conversion
As I am thinking of converting the attic space above the 2 car garage into a storage room sometime this spring...as I am wondering if I have to add something in there beside the insulation on the attic floor and put plywood on the floor....
As far as I know that to spread the weights of the stuffs/boxes around to "stabilize" the floor of the attic...
So what is the proper thickness of the plywood floor panel should be for the attic floor???
Any informations or any additional informations are welcome....
Thanks,
Rick
Thanks,
Rick
Attic conversion
NEVER cut any structural member of a truss! Any field modification that involves the cutting, drilling, or relocation of any structural truss member or connector plate shall not be done without the approval of the truss manufacturer or a licensed design professional.
Be aware that the trusses most likely were not designed to carry additional loads on the bottom chord, if you are planning to use the attic space for storage. If this is what you are planning, you would be well advised to contact the truss manufacturer as to the amount of load the trusses were designed to carry.
Frequently Asked Questions. TRUSS REPAIRS & ALTERATION. Wood Truss Council of America. Retrieved 05 December 2002. http://www.woodtruss.com/faqtrussrepairs.htm
