repair attic entry
I have pull down stairs to my attic and the brackets that the springs are attached to are loose and bending. i would like to repair it instead of replacing it. Where can i get parts? or info?
Replacement brackets
There should be some identifing markings on the unit to let you know who the manufacturer is. If you can not find any you can visit your local home improvement store or lumber yard. They should have a display or liturature that you can look at to see if anything similar exists on those products. If there are parts that you can use the store can call the vendor to see about just ordering the parts.
