basement insulation
Old 12-26-02, 09:58 AM
winger #1
Question basement insulation
I am in the process of beginning to frame in my basement . I have no water as of yet. This is a new construction that is 2 years old. I am looking for info on whether I should insulate the wall before I put the 2x4 studs up or after. Do I need to insulate the walls? If so what would the best form of insulation. Foam or Fiberglass?
Is there any prep I would need to know. and one last question can anyone recomend any books on basement ideas or plans for building a bar
Thanks
Old 12-26-02, 12:44 PM
Doug Aleshire's Avatar
winger #1,
Within the basements section, you may want to do a search on various topics concerning basement wall framing and insulation. I would suggest 2x4 walls/W/T bottom plate - walls to be placed 1 inch from exterior. Apply kraft faced insulation - R-13 - NO THICKER with paper inside room then apply your wall covering. I have suggest poly on the block - attaching it to the floor joists to just "let it hang" because I have heard members placing R-19 in a 2x4 wall and the insulation is touching the block - moisture will destroy it and act like a wick for water to your studs! You can use unfaced-friction fit then apply 6 mil poly if that is your preference.
Since you have not had any water problems, you are lucky although, you may want to apply a waterproofing paint to the interior block walls as a safeguard ...just in case.
You may want to do a internet search on bar plans but I am assuming that you may end up having to buy a book or possibly try the local library. Next option is to design one yourself and just get a book on cabinet making/upholstery. Diamond tuck (LOL - don't you love the 60-70's look?!)
Hope this helps!
Old 12-26-02, 12:59 PM
winger #1
GOOD INFO
Sounds like good info Thank-you
It probably would be better to place the poly before the studs go up then correct.
Thanks for the prompt response this has been my first time on this web site.
I'll be back
Old 12-26-02, 01:14 PM
winger #1,
You would install the poly behind before you place studs, if you want to. Like I said, just let it hang, you don't want to block air movement between it and the block because that could lead to a condensation of moisture that could cause trouble. This is in the event you are installing thicker insulation but normally R-13 is the best way. The 1 inch space ensures that your studs won't be in contact with the block and cause premature damage by moisture.
Glad you'll be back, we most likely will be here!
Old 12-26-02, 01:33 PM
winger #1
Thanks Doug
Have a good holiday
