Framing Walk In Closet
Doing the bsmt and want a walk in closet in the bathroom. Not real good at angles and wonder if anyone can tell me the angles I need for this plan. 22.5 or 45 or whatever for the top plate and sill plate. Drawing is crude but I want to come out from the back wall 24" then angle the door then go straigth to the wall. Want the left straight run from the left of the door to be at least 13" wide as I want to run shelving along the side wall and back wall (L Shape). Want the width on the back wall to be about 40" and want to use a 24" door. Don't know how to figure the cuts out. Can anyone help, also how do you run the studs with these angles?
I attached a file which showed the general layout but don't know if you can read it. I'll try to describe it better. Back of closet can't be more than 44" wide on the outside dimensions. So I would come out 24" from the back wall starting 41" from the left side. Then angle left to accomadate a 24" door than go straight to the left wall with at least a 13" length. I know the width of the closet would determine how deep it has to be with the angles. Does this help?
