short term solution
short term solution
Hey, everyone. A while back, y'all helped me with a leakage problem in the basement. I am convinced that I have a seepage problem, probably water in the blocks. I am going to battle that form the outside but I also want to shore up inside. I know where the water comes in...hydraulic cement? Regular cement? some other stuff? I can get to the spot(s) but not too easily. All opinions welcome and solicited.
Thanks
Thanks
You can give hydraulic cement a try. If it is a hard to get at place, you may not get it in just right, then it will not work real well. If your not comfortable working with it, I would just call a concrete man in to apply it. It should work if applied correctly. Good Luck
