Crack in basement Wall
I am refinishing a basement that was previously done by the previous owner.
What a bad job they did.The stud were up agains the wall with no insulation and regular 2x10 for bottom plate and paneling on top.When I remove the panel
You wont beleive the amount of mildew I found on the stud and behind the panel.
Now I am reframing with 2x4 leaving 1/2" gap between the stud and the concrete wall with pt plate.The Question is I have a hair line crack on the concrete wall , Its start at the corner of a window and go all the way down to the floor.Any one know How I can fix that?
peppy,
Go to Home Depot and look at the Drylok products available for this. Other brands are available for cracks including hydraulic cement applications.
Hope this helps!
Hope this helps!
