Framing around breaker box
My main circuit breaker is hung on a peice of plywood that is in turn nailed to my poured walls via masonry nails. The location is in the corner of what will be my main entertainment room.
I already have a couple of ideas on how to handle this. I can frame around the box. Since I'm starting the walls out an inch already, the plywood won't interfere at all. Then I can build a cabinet door into the wall for access. My main concern with this option is the loss of insulation in that area. Probably not a big concern, since it'll be a pretty small gap in the insulation.
Another option is to build a very small closet around it and then insulate the walls of that closet. Not sure I like this, because it's kind of intrusive and requires a larger door.
Any other ideas or thoughts on this?
I have the same situation. I have a sump pump, electrical panal and a mitigation pipe along one wall. I was thinking of doing a 8 foot closet with folding doors. I thought I read some where that you needed at least 36'' clearence in front of the electrical panal. I to will need some insulation ideas.Griff
There are a lot of clearance requirements for a panel. The main ones are 36" in front, 30" side to side, and 6'6" of headroom. The space within these dimensions must be completely clear of everything. The panel must also be readily accessible, and not be in a clothes closet, bathroom, or in the vicinity of easily ignitable material.
