Steel studs/door framing
I'm in the middle of framing out our basement using steel studs. Originally I was going to frame the doors with wood 2x4's, but after finding it almost impossible to find a straight piece - I decided to frame the door openings with steel.
I used double steel 2x4's on each side and a a piece of channel for the top. Cripple studs help support the top channel as well as the ends that have been bent down to screw into the side studs.
The openings are solid - I could probably hang on them and it wouldn't budge. My question is that I've seen some posts with people saying you have to use wood around the frames to hang the wood prehung doors from local hardware stores.
Is this true? I don't foresee any problems using screws and shims to attach the door frame, but I'm starting to wonder if I'm missing something!!
Thank you for any help!!!
Glen
Glen
Gabling2,
The issue is attaching everything else as well, like casing. It's just easier have some wood to nail into - you can't screw everything in! Just break out alot of wood putty to fill holes! Same applies to use of steel plates, it's better using a wood treated plate so you have wood to nail your base trim into. You're the boss, do what suits your needs!
Good Luck!
Good Luck!
Good point with attaching the casing. I did put 2x4 treated plate under the bottom steel plate. First for code, second to be able to nail in trim versus screwing it in.
I really would rather just shoot in finishing nails for the casing then having to screw it all in - what a pain that would be!
Thank you for your quick reply... I'm off to the local hardware store to see if I can find some STRAIGHT 2x4's!
Glen
Glen
Gabling2,
Just a thought, take a look at this link;
http://www.bmp-group.com/pdfs/ADVANT...OF%20STEEL.pdf
Hope this helps!
Hope this helps!
Doug: Thanks for the link. I've followed variations of this page to actually do the framing that I've completed. In this article they stud out the frame openings with steel. I guess like you said, it's just whatever suits your needs.
I have two doors done, so it shouldn't be too difficult to remove the side studs and replace it with wood. I'll have to think about it - I'll see how tonight's work goes and how much I finish.
Thanks again!
Glen
Thanks again!
Glen
Glen,
You're very welcome! Have fun shopping and hope all goes well. Glad the links helped some. I have seen different variations of steel framing in cooperation with finish carpentry details. Let's face it, you should be using some wood when you consider steel framing. It's easier for everyone and for future alterations.
Good Luck!
Good Luck!
